- Jul 17, 2010
- 1,060
- 24
- 0
Greetings,
As I'm sure everyone knows by now the Droid X updates your battery life in intervals of 10%. I personally find this to be not only annoying, but uninformative. Lets say for example, I plug my phone in and charge it to 100%. 30 minutes later after unplugging it and using it some, the battery now claims to be at 90%. What does this mean exactly? Does this mean its at 99% and rounds down? Does it mean its at 94% and rounds down, but claims 100% when its 95% and higher? Or how about another 5 minutes later, when it still says 90%, is it really 90% or is it somewhere between 80% and 90%?
These are all problems that would disappear and lead to a more informed user on proper battery life had the system shown intervals of 1%.
The reason I bring this up is to ask in everyone's opinion, is this something that can be fixed in a firmware, battery replacement or other possible fix, or are we stuck with this simply due to hardware limitations inside the phone itself?
I'm pretty sure no one in their right mind would prefer this confusing system over an accurate-to-1% indicator so please, if you guys feel the same lets try to report this to Verizon and/or Motorola to get some solid information and possibly get a fix in the works.
Thank you
Thank you
