Question for Galaxy Gear owners...
MLdroidN4
130
I'd like to know if there is an option to manage what notifications get pushed on to the Gear from the Note 3. For instance, I'm having lunch with a co-worker or a colleague who is sitting across the table from me and I'd like the Gear to not display any incoming calls or texts on it. So can I easily go in the Gear Manager app and disable such notifications or I'll have to un-pair the Gear from the Note 3 to disable that?
I know the whole purpose of the Gear is to have the accessibility of receiving and making calls without having to use the phone, but some situations call for it otherwise.
I'd appreciate Gear owners' input.
Just turn off Bluetooth on device. When you reactiveate Bluetooth then will synch up like normal
Sent from my SAMSUNG-SM-N900A using Tapatalk 4
With Gear Manager you can enable or disable specific notifications for Gear, including incoming calls.
Texts and other notifications aren't displayed until you tap the notification screen and then tap the actual notification you want to view, so you don't have to worry about anyone seeing any of those inadvertently. As for the calls you can either disable Bluetooth on the gear or phone, enter gear manager and uncheck calls during that time, or if you push the power button on the gear when a call comes in it blanks the screen and silences the ring.
Thanks for all the responses. As long as there is an option to disable calls, I'm golden. :) For some reason I assumed incoming calls will always be displayed(with no option to disable) on the Gear as long as it is connected to the phone.
Ninjja
