Question on UMX MXW1 Android phone, can I get some help?
A
AC Question
Question on UMX MXW1 android phone
I have never had a smartphone before and there is very little info that came with this phone. I want to buy an SD card for it and found one on Ebay but it has this warning: YOUR DEVICE MUST SUPPORT AT LEAST 128GB OF EXTERNAL MEMORY. How can I find that out? Is there a specific kind I should get and if so how do I find out what that would be? I would appreciate any help I can get. Thank you in advance.
the tall guy
Q&A Team
Sep 23, 2013
7,210
Re: Question on UMX MXW1 android phone
Hi, not many phones come with 128gb capacity for SD Cards. I would stick to buying a 16gb or 32gb SD card for your phone. If you Google UMX MXW1 there are a couple of vidoes showing you the phone, which might help explain where the card goes. Also on their website - UMX Mobile Phones you can find more info on the phone.
Budget Mobile
Hi. You can refer to my video links on Youtube as described, but I can tell you this phone WON'T support 128GB of MicroSD Storage. Please try the recommended 2GB MicroSD which Budget Mobile suggested/works without fail.
UMXMXW1
Howdo I add Gmail app to my UMX MXW1. Down loading the app says the device is incompatible.
Thanks for any assistance or information
Larry
I know this answer comes later then expected... The preferred method I would use is"sideload" the application via .APK file or try a similar version #. If you install via that method instead of using the Google Play Store, you'll likely find an .apk of the program you wish to load/run.
