4 4dandroid Member Jul 23, 2015 13 0 0 Aug 26, 2015 #1 With regards to the Nexus 6, will Marshmallow activate the notification lights without root? Also, is there a silent mode available. Thanks.
A Aquila Retired Moderator Feb 24, 2012 15,903 0 0 Aug 26, 2015 #2 The Nexus 6 has notification lights? It has total silence, vibrate only, priority only, etc.
pony182 Active member Jul 1, 2011 33 0 0 Aug 27, 2015 #3 I don't see that option in developer's preview 3... Sorry.
T TacoKingYo Well-known member Apr 29, 2015 149 0 0 Aug 27, 2015 #4 Assassin Droid said: The Nexus 6 has notification lights? It has total silence, vibrate only, priority only, etc. Click to expand... Yes, it is hidden by the top speaker grille. With Lollipop, it is only turned on by rooting Posted via my amazingly smexy Nexus 6 yo
LeoRex Retired Moderator Nov 21, 2012 6,223 0 0 Sep 23, 2015 #6 4dandroid said: With regards to the Nexus 6, will Marshmallow activate the notification lights without root? Also, is there a silent mode available. Click to expand... No lights.... There have been modifications to the 'Silent' mode... but you'll have to look into whether or not it suits your needs. It seems everyone has their own particular view on what silent mode is and since 5.0 dropped, it can get complicated.
