Quick how to: Add battery percentage to your battery icon
cane prevost1
151
If you've ever wanted to see the battery percentage remaining on your battery icon here's a quick way to get it without having to download any new software:
1. Swipe down to reveal your control center. Tap to open it. Find the gear icon and press and hold for about 5 seconds.
2. When you release you should see a popup that says that System UI tuner is enabled.
3. Go to your settings and scroll to the bottom. You will now find System UI tuner.
4. Open UI tuner and flip the switch for "Show embedded battery percentage" to on.
5. Profit.
KillerQ
1,091
24
It is the simple things like this that make me appreciate ANDROID more than any other system.
Posted via my Nokia 8210 from the inside of a Kitten.
Billy Bob Jimmy Joe
603
I've been using this feature since I got the 6P. My only gripe is that the battery icon should be horizontal to make it easier to see the percentage.
Google Nexus 6P
dmitrbol
