Quick Look: Brushed Aluminum Battery Door
Very nice! Gives the Note a very elegant look.
Sent from my GT-N8013 using Android Central Forums
Have you confirmed that the case interferes with the NFC abilities of the phone like the eBay seller warns?
I might need to get one of these, it would look great on my grey note 2.
Sent from my SCH-I605 using Android Central Forums
That's hot! Too bad my case would cover it, or I'd be all over it.
Sent from my Samsung Galaxy Note2
I haven't. I assume I'd have to remove the NFC piece in the OEM battery door. I don't use it enough to bother.
Is that the silver door that you've linked to? I have the titanium and the silver in the ebay posting looks too light. Also, what version do you have?
Sent from my SCH-I605 using Tapatalk 2
Yes, the link I posted is the one I got.
AT&T.
That is pretty awesome looking, nice way to add an upscale look. But it would be lost on mine, OtterBox Commuter on the way for me.
I have the purple one, with a bumper type case around the edges. I love it, though I'm not sure how to remove the nfc thing off the oem cover to put it on the purple one?
Sent from my GT-N7100 using Tapatalk 2
Does anyone know if a bumper case with frost back will fit with the aluminum back cover
Those back cover are really nice if you don't mind losing nfc.
I have a red brushed aluminum one on mine with a aluminum bumper case. Makes it look very luxurious
Sent from my SGH-T889 using Android Central Forums
Pics? Very curious to see what you are referring to.
Hi, it looks the business and just what the note 2 needs! Its the only thing I dislike about my awesome note 2, the crappy plastic back cover and Ive been looking at these myself. Wondered if you could help me with a few questions? Does it affect the overall size or is it a exact replacement of the original? Also, does it add much weight to the device. The other thing I worry about is does it affect your signal either cellular or wifi at all.
Cheers
Lawrence
I rarely see the back of my N2 because I keep the Samsung bumper case on it. Now if they made a bumper case with a brushed aluminum back, then we'd be talking.
Beautiful I have a grey phone and would love that
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Damn Dreya
