- Jan 30, 2014
- 131
- 0
- 0
My problem is, when I leave wifi on and go out of range then come back into range the quick remote appears on the lock screen. The quick remote is toggled to off on the notification drop down, and also the option for wifi is turned off under quick remote options. So to get it off the only option I have is to launch quick remote, go into options, select turn on when in wifi range, add my home wifi network, delete the home network then uncheck turn on when in wifi network range. Please God tell me it's something simple to stop this from happening.
OGpro_2_AC
OGpro_2_AC
