Radio and PRI updates - will they help me?
FractalSphere
223
4
This might be a newb question, but I've seen very little specifics on the radio versions and requirements.
OK - I'm running Baked Snack 1.8 (a one-down older version, yes - 1.9 had issues for me)
PRI 1.40_003
Radio baseband
2.15.00.09.01
PRL
60677
So I'm wondering if I need to or should update radio updates and/or WiMAX updates? Would they benefit me?
ALSO -
If one update stops my phone from rebooting, and I've previously downloaded multiple versions of the radios, I can still get into the boot loader and flash another version of the file, right?
PRI 1.40_003
Radio baseband
2.15.00.09.01
PRL
60677
You could benefit from updating your radios. Are you having any issues???
I'm running a latter version of the radio baseband(2.15.00.11.19), PRL(60675) and I can't find the PRI version on Miui(going to have to do some research on that) and I'm not having any issues so I'm going to go with that old saying... if it ain't broke, don't fix it.
As a rule of thumb with flashing roms, every once in a while I flash that Sprint Lovers rom over at xda. That rom gets update with the most current radios from time to time.
ALSO -
If I'm reading this part right your asking if you update your radios to a newer version can you flash back to an older version if they give you issues? As far as I know... yes you can. When I was still running sence based roms I remember having an issue with a rom and the fix was to flash an older radio version.
Sent from my MIUI havin, Gingerbread Throwing EVO
godef
