• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
RAW DNG to Jpeg converter for Samsung S7
  • Thread starter Android Central Question
  • Start date
A
I have tried several apps but they either don't recognise the DNG format or they are simply useless for other reasons e.g. always writing the output to some directory (folder) in the device filespace which one then has to move them out of.
I need something which can convert them from the SD card
e.g. 0000-0000/DCIM/Camera
to the same place.
The S7 is rooted, with SDfix etc.
I would appreciate any tips.
The app shop is like the IOS one - 90% junk and you need five apps to get any one job done :)
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
I did a little research for you. It seems that saving the results to the SD card is something that Android is prohibiting, so it's not the app. None of the RAW-to-jpg converters can save to the SD card. (Probably because none of them create an output folder on the card.)
Ask The Community
geetermak69
