Realistic fast wireless charging speed
YuanhaoYoung
12
3
3
I recently bought a fast charger for my car (Rocoren 4-port PD, which supports up to 30W) and a wireless charging phone holder. When I put my phone in the holder, it says Fast Wireless Charging, so the phone can detect the charger supports fast charging. But eventually this changes to Wireless Charging. Using AccuBattery, I can see the wattage varies between 2w and 3w, which seems low. But if I go into settings and turn off Fast Wireless Charging, then the phone takes even longer to charge.
I also tried this with an Anker fast wireless charging stand and got pretty much the same result.
Realistically, should I get closer to 10w or 15w? If not, what should I be getting?
At what battery level does the charging rate drop down? Keep in mind that as the battery approaches 100%, charging rates always slow down -- it's the nature of how a battery is charged.
Reactions: Laura Knotek
It doesn't seem to matter. I've seen this when the level is around 50%. I do have the protect battery setting on, to limit max to 85%.
I forgot to mention that if I connect directly to a fast wired charger, it works great. Very fast at the same battery levels.
Does the phone get pretty warm while charging wirelessly? That might also affect charging speeds -- it might automatically drop down to slow charging as a safety measure.
I'm not sure. I'll have to check that, although I think it starts off slow even before it's had a chance to warm up. Thanks for the suggestion!
Reactions: B. Diddy
Are you charging more than one device at a time? Which USB port are you using?
Which wireless charger are you using with that USB car charger?
Reactions: mustang7757
I recently bought a new Anker wireless stand which supports fast charging. But when I tried it with any of my existing USB charger plugs it would not go fast. I then realised I also needed an new USB charger plug to use with it that could deliver the extra power it could accept. From what I could see an S20 only accepts up to 19W anyway and in practise that seems to take about 50% longer to charge than a direct cable.
(I have an older wireless charging stand in the bedroom that does not do fast charging but as that is for overnight charging then not an issue)
I'm only charging the one device, and I made sure to use the port marked as 67W/30W.
B. Diddy might be on to something with temperature. This morning when it was cold in the car, I saw much higher wattage, up to 7W-9W range, with the battery at 80 degrees F. In the afternoon, with the battery at 96 degrees, charging seemed slower. Unfortunately, the car is going to be warmer most of the time :(
Reactions: B. Diddy
Yeah, that may be a safety mechanism. You don't want to be charging a battery at high speed if it's really hot, since that would increase the risk of fire or explosion. 😣
Thank you to everyone for your input. I've been checking, and the wireless charging does seem to be much faster than it's cold. However, wired fast charging is still faster at the same temperatures. A limitation of wireless charging, I guess. In any case, I'm happy the mystery is solved, and I'm still getting better charging speed than before.
I also turned on battery protect, so it stops charging at 85%. That should protect the battery somewhat.
Reactions: B. Diddy
used to be 1000 charges before deterioration of batt!! :cool:
It can depend on your definition of "deterioration" -- i.e., when does the user really notice the decreased battery capacity? That could be anywhere from a battery health of 85% (for the meticulous/obssessive tech nerd) all the way down to maybe 60% (for the more run-of-the-mill user).
Battery University, which is widely regarded as one of best sites for battery info, says that in 2020, the average smartphone was expected to last at least 800 cycles, but this is also tricky to determine, since it depends on how cycles are measured (technically a full cycle is from 100% down to 0%, which most people don't do), and also what's considered "end of life" for a battery, in terms of its battery health -- 80%? 50%? 0%
Reminds me of my Galaxy Watch ; they also charge wirelessly. The GW 6 models start off, in theory with 10W speeds but soon drop down really quick due to the heat. Heck, during peak summer time [read: temperatures exceeding 40C] , I have seen the GW4 outright refuse to charge after being put on the cradle for sometime. Contrast it with my phone with actually did charge in a wired manner quite fast [it might have too throttled from it's stated limit of 45W but sure as heck didn't stop].
The heat generated during wireless charging is a major deterrence.
800 will go by quickly if phone charged every day :cool: !! i'm a light user, sometimes get 5-6 days on charge to 100%!!:cool:
But let's think about that for a minute -- if a user were to actually use a full charge every day (i.e., 100% down to 0%), that still means 800 consecutive days of use, which is more than 2 years (and many people trade in their phones for a new one every 2 years). Realistically, most people will end up going from 100% down to maybe 30-40% by the end of the day, which is actually a partial charge cycle, not a full one -- so that means significantly more than 800 days. And yeah, if you're a light user, you're extending the life of the battery even more.
Nobody
