Really Annoying USB Problem
HeliosKBH
Hey everyone,
I've had my Iconia for a while now, but I've been having the nagging problem...I can't get any access to the internal storage when I connect it via USB. Before the recent update (not 3.1) Nothing would happen, now after the update, it says it's connected in Debugging Mode, but even if I turn debugging mode off, it will still come back on.
I'm running Windows 7 Ultimate x64, and in the device manager the tablet is coming up as an unknown device. Drivers from Acer don't help. Other USB devices work fine, and the USB connection works on other computers....
Any ideas??
Thanks!
Have you tried to uninstall your acer usb driver.That's what I would do. after you uninstall it reboot your computer then plug the Acer into a different port and reinstall the drivers.That may help you out. Are you plugging this directly into the usb or through a hub?
Try it in one of the rear usb headers. Just to test it out.
dewiit
