Rear camera flash doesn't work on G3 D850?
billwx
Bought my LG G3 D850 used at auction. When taking photos with the rear camera the flash icon is greyed out and evidently cannot be turned on, otherwise the phone works perfectly and i love it. The front camera flash works as expected. Is there a toggle somewhere i haven't yet found? Thanks!
Open the camera and then hit the Settings button. I think you will find that you have HDR on, in which case flash is disabled. Touch the HDR button to toggle off and you will see flash icon become active.
You are exactly right! Thank you so much! Three months and i thought i had no flash. I don't often use it, but glad to know it's there and working as it should.
KidColoringPage
