- Aug 7, 2012
- 13
- 0
- 0
I've run across the dreaded reboot problem with a little bit of a twist. The issue arose out of nowhere today and I've not had much luck with any of the solutions offered in the threads here. I've booted to recovery to try a factory reset, but it restarts again before I can get anywhere. I've also tried constantly mashing the power button with it plugged into a USB port, which sometimes will allow it to progress a little. It then says it's optimizing apps (as in an OS update) and then reboots partway through, usually around the 80s.
It's an unlocked N5 on AT&T running stock 5.1 about 2 months past warranty (of course). No prior battery issues, or issues of any kind at all, really, until it took a mind of its own at recess duty today. Any help would be appreciated.
Thanks,
Brian
Thanks,
Brian
