Recommended Mid-range phone with above-average battery?
DarcMobile
5
Hi I'm looking for mid-range Android phone for my friends
Here are specs that I care about:
- Above average battery life :cool:
- At least ICS 4.0.3
- At least 4" Screen
I'm considering Galaxy S2, does it has great battery?
I can't really calculate it based on mAh alone because my Galaxy Nexus battery sucks compared to others with same mAh.
Any other suggestion?
One of the devices that you may want to take a look at is the Samsung Galaxy S3 Mini.
It's a scaled down version of the S3, but looks to be a pretty good device that satisfies the criteria in your post.
I'd say that if you were already at the S2, then the S3 Mini should make it into your consideration set.
Best of luck.
Sent from my SGH-I317M using Tapatalk 2
Best of luck.
Thanks for the reply, but S3 Mini has lower battery mAh but with same resolution as S2.
Does that makes S3 Mini last shorter than S2?
britnroberts2018
