Redmi 9i miui 12 android system battery drain
  • Start date Start date
A
Android Central Question
It been around three months on my redmi 9i and i am having battery drain of 1% at every 10 minutes; using wifi and screen hours of around 5 hours.Android system power usage is at 37% of my battery.
Welcome to Android Central! @mustang7757, MIUI 12 doesn't correlate directly with the Android version number. I'm guessing the phone is still on Android 11.
To the OP, is this behavior new, or has it been like this for a while?
Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
Maybe their own beta then ?
https://www.xda-developers.com/down...ing-out-several-xiaomi-redmi-mi-poco-devices/
