Remote Call/Pull
Daniel Padilla
79
I have a recurring notification for "Remote Call" that says "Pull" at the bottom of the screen. Has anyone seen this before and how do you get rid of it.
Looks like it's part of the Phone App.
doesn't mean it is. try going to notifications and let all the apps with nots enabled load. turn off anything that doesn't need to notify you and see if that helps. if not, try turning all off and if it goes away then it's one of them that you think you need and don't necessarily. apps can be sneaky and appear to be part of the os. worth a try if you want it gone.
