Replaced Digitizer, No Sound through Earpiece
tehjosheh
10
So i successfully (sort of) replaced my digitizer to find that everything functioned correctly except for one thing; i have no sound through the earpiece.
I do have sound through the speaker, but the actual earpiece used in-calls does not produce any sound.
After assembling the phone, i disassembled again and reconnected every ribbon cable to see if that was the issue - it was not. I did, however, notice when looking at the white and black wire that i had punctured the black wire with a screw.
Could this be the issue? If so, should i just try to add some solder to the exposed wire and maybe electrical tape it up??
any help/info would be MUCH appreciated!!!
Thank you.
Thank you.
Yes. Worth a shot.
Sent from my HTC Vivid WCX using Android Central Forums
