Hi,
I had rooted my gf's optimus s using the gingersnap utility and flashed reborn rom while it was running the vc baseband by mistake which I had forgotten it was running vc until after the fact. I know I'm a dummy.
And everything seems to be working, it rooted just fine, the custom recovery flashed fine and reborn rom is running fine. My questions are: should I go ahead and update to vd using lg updater tool? If so, will it remove root or brick the phone? Or should I just leave it on vc since everything is working? Any help would be appreciated. Thanks
Thanks for everyone's help! Got it resolved!
