Rezound battery heat
SirKnightDavid
Active member
Apr 6, 2012
31
Hey all. Newly switched from the original Dinc to the Rezound and loving it so far. One thing I noticed today though is that I can only play Temple Run for about 1/2 hour before my battery heat goes up over 120?. Is that normal?
Yes, that's the default setting that triggers the temp. notification light. No biggie though you won't do any damage til around 135-140. Those are temps you need to worry about, Be cognizant of the temps and let it cool down before 130. Put a fan on it or leave it alone, melted plastic on skin isn't a pleasant experience.
Hey all. Newly switched from the original Dinc to the Rezound and loving it so far. One thing I noticed today though is that I can only play Temple Run for about 1/2 hour before my battery heat goes up over 120°. Is that normal?
If you are within your 2 weeks, you could get it exchanged for a new one. Some people think that some run hotter than others. Mine gets to 120 and doesn't go any higher.
Sent from my Kindle Fire using Tapatalk
I'm not sure if it will go above 120 off a charger but the Rezound will if it's being used under a heavily loaded gpu while plugged into the USB juicing up.
Thanks for the replies, good to know its kind of expected under heavy GPU strain. Having to put Temple Run down every half hour isn't necessarily a bad thing anyway... that game is stupidly addictive ;)
Mudasir
