Rezound battery = TB battery
jas o
475
28
For all TB people the battery from the TB works in the Rezound.
While the VZW CSR was transfering my SIM card he said boy the the TB battery and the Rezound battery look the same. I wonder if they work. I asked if he more phone in the back and he said yes so I told hime give it a try before I took ownership of the phone.
It started up no problem, no smoke.
Reactions: skyjjc
Most HTC phones use the same battery size which is nice to swap to a bigger one from a different phone. :D
Nice, so the extended stock-sized batteries will fit with the original backing with no issues.
Makes it easier to get an extra battery or two once I pick this bad boy up from the store.
ya the tb extended batter does fit in the rezound but the cover is different , so whats the point
I just ordered 2 1800 mah red batteries & charger for mine ..... fits with regular case. Look on Ebay. Kinda takes some wind out of the Razrs sale ;)
Cheers :)
Just a warning, often the cheap eBay extended slim batteries are lower capacity than advertised. Possibly lower than stock.
Rabble rabble rabble.
Not the Incredible. No go in the thunderbolt. Can't assume the battery will work
Sent from my Thunderbolt using Tapatalk
Cheers :)
I got 2 of those same batteries back in May or so, right after I got my Thunderbolt. They don't last as long as the stock TB battery and one of them is already crapping out - i.e. not lasting nearly as long as it did when new.
Just FYI. I'm really thinking about buying a stock OEM Rezound battery to use in my TB.... or just buying either a Rezound or a VZW Nexus when they come out.
