- Oct 7, 2009
- 3,536
- 1,441
- 0
1) Call Sprint tech support and get your MSL (six digit number)
2) On your keypad dial ##DATA# (##3282#)
3) Select "Edit Mode"
4) Type your MSL as the password and hit "OK"
5) Select Advanced
6) Change your "Slot Cycle Index" to the value of 1 (explination below)
7) Press the Menu button
8) Select "Commit Modifications"
9) wait for your phone to reboot
10) Click the scales on top of this post to add to my rep!
Slot Cycle Index (SCI) - You can tweak your Slot Cycle Index (SCI) to make your phone poll the tower more often. This makes your texts and phone calls come through quicker. This setting is a trade off between lag (most noticeable when receiving calls) and battery life. The default value on our phones is 2. Every step of 1 adds 1.28 seconds to the poll time, so at a value of 2 it is only polling every 5 seconds or so. If you lower this to 1, the phone polls every 2.5 seconds. This won't affect battery life much in areas of good coverage, but may impact it noticeably if you're in a poor reception area.
5) Select Advanced
