Ringer Volume again
lookin4fun
13
Okay so I have searched every forum I can find and the only way to make my ringer volume louder seems to be to root my phone and change it that way! I to like matt512 from an earlier post cant hear my phone ring from its case or my pocket! My 8830 curve on its lowest setting is louder than my Droid X on its highest. I have read the post on rooting my phone and Im still not all that comfortable doing that just yet. Only had the phone for 4 days! I had an app for the curve called Berrybuzz that made missed notifications remind better than all the apps that i can find for my X. Does someone know if there is something better than Easy Reminder that will actually work for more than 4 minutes before it stops reminding me? Yes I know being a newbie I deserve some razzing if I missed something to fix these problems. So fire way LOL
The official 2.2 should fix your volume. I don't know how u can fix it with root. The leaked 2.2 did make my ringer much louder. Wait it out a week or two 2.2 should be around the corner if you don't want the leak.
Sent from my DROIDX using Tapatalk
Will wait and see did do a couple of "hybrid" up grades to my BB still havent put my first "scratch" on the X so I will wait and see how 2.2 does thanks tntdroid
rooting alone willl not fix anything.
the leaked 2.2 upgrade has addressed the voulme issue. it is definetly louder but i think it can still be increased more.
anyway i would check you phone aroud noon today for an update......
settings>about phone>system update
The ringer issue whether hardware or software related must be limited to select handsets.
My Droid X is so freaking loud I have to keep it at half volume levels and I am just using stock 2.1
Why noon? I've found most updates go out overnight/late night
Try the app called "missed call" it has customizable reminders for missed calls and sms.
Will check it out! I wish my phone was so loud I have to turn the volume down. I was sitting in the truck the other day at a stop light and my dad was in the passenger seat couldn't hear my phone ring on the center console between us! LOL it was on his good ear side too:p
Maybe yours is the broken one lol
why not try installing a louder ring tone by using ringdroid or zedge...this may help.
I have 2.2 on my phone and used "Noisey One" for my ringtone I can here that thing on the other side of my house with pillows stacked up on it.. Well not really but you get the picture
SeVeR
