Roaming
Shocktribe
69
Whenever I make a phone call it says I'm roaming, does anyone else have this problem?
Who is your cellular provider? Where are you located? Have you checked your provider's coverage maps to see if you are in a roaming area?
Yes, check your carrier's coverage area. You might be outside the coverage area - also check with the Carrier's roaming policy. If you roam too much or are not supposed to roam at all you can accrue overages. Just a precaution to check the above.
I've been wondering about this from the other side. I've got roaming turned off (I'm on an AT&T plan) on my Nexus 5. I don't think AT&T charges anything for domestic roaming, so should I have it turned on instead?
958ryan
