Roaming? ?
ansa82
1,899
116
63
In my basement with a great wifi signal? Why on earth would I get a warning about roaming?
sent from my Note 3
It's about your carrier's signal, not the WiFi signal.
Can you post a screenshot of your home screen?
There we could see both, WiFi and carrier signals.
Sent From Another Galaxy
Settings ...more settings..mobile networks..global data roaming access..allow access for all will remove the notification. It might be you went outside(driving) and came back and the notification was still there,it stays on until you allow in settings or restart.
sent from my Note 3
I just got it again! It says roaming. I'm in my family room with wifi 2 rooms away. Today is the fist I'm seeing these notifications about roaming. Here is a pic of my home screen:
sent from my Note 3
sent from my Note 3
At least, in that screen shot...there is no indication you're roaming. It shows a couple of bars of signal (for the phone) with 4GLTE data available...but it shows you're connected to WiFi for data
Sent from my Note 3 via Tapatalk
I'm thinking it had something to do with the fact that we had a pretty bad storm here last Sunday. Monday thru Wednesday many homes & businesses without power. Maybe my wifi was going out and I didn't realize. I don't know but thankfully the random "roaming" message seems to have stopped.
sent from my Note 3
sent from my Note 3
Are you in the part of Michigan that's by the Canadian Border? If so, picking up a signal from a Canadian tower would show as Roaming.
To avoid that in the future...make sure you set your network data to deny data access when roaming.
Yes I'm in Michigan. Thanks!
sent from my Note 3
