PvilleComp
- Jun 13, 2010
- 4,137
- 603
- 0
Thanks... Thats what I thought too. I guess I will just stick with the CM version instead of getting two texts and taking up space. if you do find out otherwise, please let me know, and I will post it too if I find out a way...![]()
In the messaging settings, you can change the number of messages to save per conversation. The default is 200 SMS and 20 MMS. You could reduce those in the CM messaging and see if it has an effect on Handsent. If not then just set it to one for each and then your space problem is solved!
