ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] gROM 1.1 - 9/16/11 - GB 2.3.3 [Official!] It just got r
+1
And as another side note, after reverting back to stock gRom, my double tapping
selecting problem has went away.
So I would just say don't flash any other Kernels as of yet. Just my
******ed 2 cents.
Your 100% correct. So I would say $1.00! lol
Updated Important info in post #2 as follows:
[WARN]Prerequisites
Must be at latest Sprint VH baseband and rooted. More Info here: http://forums.androidcentral.com/lg...-rooting-ls670zvh-temporary-instructions.html
Must have a custom recovery installed. More info Here: http://forums.androidcentral.com/lg...covery-xionia-clockwork-cwma-v1-2518-6-a.html
Do no flash any kernel with this ROM unless I specifically say its compatible. Others have claimed compatibility but they are not. They cause intense screen issues. At this time there is no compatible kernel for this ROM!
[/WARN]
Hi Scrosler,
where you able to replicate the headphone problem?
I know playing music works, however, when I try calling out no sound comes out of the speaker.. :(
Thank you.
Hi Scrosler,
Thank you.
I have not had time yet to do that specific task about others here report there is no issue. I should have time tomorrow if I can find the headset. If not I will grab a cheapo one at Walmart.
I posted Android Market version 2.3.6 in the OP for those that want to revert. You simply place on SD card and install using ES File Explorer. Select yes to overwrite system file.
I pulled out of the Epic 4G touch system dump so I assume its a pretty recent version.
-Scott
I have actually noticed my phone and data being faster as well as batttery life improvement. I dont know how the battery life improved but it def did.thanks for the ROM
Thanks!
X2 improved on both though I have noticed issues moving things on the home page and double tappping of letters lol.
i didn't know a zvh rom was out this is awesome!
-Scott
Trying to download but keeps coming upon untitled an fails I don't think it is my phone cuss I downloaded lockbot pro from another site
I tried with PC, phone browser, and Tapatalk. No problems.
Maybe talk to a mod?
Sent from my PG86100 using Tapatalk
No problems downloading with this ROM.
What's next for gROM 1.2?
I got some little improvements planned. Nothing major.... Maybe a revert to the older Market, a theme change to the launcher to be aesthetically true to the OS version...
Maybe power widget in notifications? O:-)
Please, please, please :)
Maybe... Well see! No promises but I will try to work that in. That's a very time consuming and delicate mod because it calls for re-engineering some low level components but I do see the value in it.
Maybe Nick7 would help with it? He mastered it in his Reborn ROM. I may send him a PM and see if he can help with this. Otherwise I need to start from scratch and that may take a while.
Reactions: memsman
I too was one of those fools who flashed Drew's kernel, I was about to throw my phone across the room with all the lag and double tapping. It was driving me nucking futs!
I wiped and reflashed and it's smooth as butter now. :cool:
This really is good work Scott, thanks for the effort.
I'd also like to add to the begging for the power controls, it's the one thing I miss from CM7.
What's that feature that combines similar widgets together when you go to add them? Reborn had that feature.
Oh yeah... I know what you are talking about it... A guy on XDA made it. I will add that too...
If you want.. Someone can start a feature request thread on Scott's ROMS - Home I have an Optimus S section there. It would make this a lot easier for me to track.
Thanks!
Reactions: mike9670
I forget the naame but it was a installable mod from xda. If I can find it ill post it.
Status
Mohamadharika500
