Rom Manager Issue! Help?!?!
D2TSHR1439
161
When I was on 2.2 I got this same message, now I am back on 2.1 . Has anyone else ever got this image or know what may be causing it??
Thanks Nick
Forgot to mention. When I click on a ROM to load, it restarts but then boots normal. Droid screen then the Eye. No Install Screen at all.
Deff need that bootstrapper. Without it you will have those issues.
Sent from my DROIDX using Tapatalk
just to clarify, you have gone either to the market or here to download the bootstrap recovery and then installed the apk and loaded the bootstrap before trying to use rom manager to boot into clockwork right?
if you have, did you try to run the bootstrap application again? if not, i'd try that too
I was also having this problem. It was unclear to me that after downloading the Droid X Bootstrapper I had to open the program and click "Bootstrap Recovery".
Got it working! You, sir, are the man!
