Rooted and now mounting USB does not work!
hayesb2
18
I've been sideloading apps for awhile now non-rooted, and copying stuff to/from my phone by mounting the USB.
Today, I decide to root using the 1-click root method, and it works fine...
However, when I connect my phone via USB (debugging on of course) and then mount my USB my PC no longer recognizes the SD cards like it did before???
Can somebody help me?
Are you using something other than the default TWLauncher (like LauncherPro)? I've found that I have to switch to the default launcher before connecting the phone to my computer. I do this by installing a program called HomeSwitcher. Quick and easy to switch back and forth.
To my knowledge with USB debugging On, It wont allow usb mass storage mode. Try turning off USB Debugging and Then reconnect it!
HTH,
Charlie
christiecharles
