Rooted, won't turn on need to send back for waaranty HELP
sr2381
Active member
May 26, 2011
33
TB won't boot up all the way. Rooted by revelutionary method. Replacement coming under waaranty but going to cost me over $200 if they find out my original was rooted. Can't factory reset either. Anyone have any ideas?
Have you done a battery pull and leave it out for 5 mins.?. Also, pull the SIM card out also. Put your sim card and the battery in and plug it in for an hour....DON'T turn it on. Try going into RECOVERY (power + volume down).
Also, download the ALL IN ONE UNROOTER listed on the forum.
P.S. Since the TBolt is old,. they probably won't care if it is rooted....it will be scraped anyways.
