Rooting problem
shydow
3
i'm following the steps from
http://forum.androidcentral.com/verizon-fascinate-rooting-roms-hacks/33899-how-root.html
but it seems like it doesn't work.. on the cmd it says
Successfully exploited, installing permanent root files and deleting temp files
Mount: operation not permitted
/data/local/tmp/com.sh: cannot create /system/xbin/su: read-only file system
/data/local/tmp/com.sh: cannot create /system/xbin/busybox: read-only file system
/data/local/tmp/com.sh: cannot create /system/app/Superuser.apk: read-only file system
Unable to chmod /system/xbin/su: no such file or directory
Unable to chmod /system/xbin/busybox: no such file or directory
can anyone help me? i'm really new at this not not familiar with computer/phone stuff so i'm in desperate help.
Hey, I recommend trying out POST #5 in this thread: http://forum.androidcentral.com/ver...-please-read-post-1-before-posting-forum.html
It's pretty easy and the steps are layed out well, just read through it follow it correctly and you'll be rooted in no time. Hope this helps, enjoy!
If you would like i can root the phone for you over screen share.
And for future reference please do not follow directions of threads that are closed, they are usually closed for a reason. Most of the time they are out of date
thank you both, i'll try it again with the new link.
and if it still doesn't work can i ask for your help, droidxcon?
and what is screen share?
Yes ....where I control your computer remotely
Sent from my SCH-I510 using Tapatalk
[/IMG]
Look up super one click on XDA, it roots your phone in 20 secs. Just don't forget to enable usb debugging before starting.
Hi I'm trying to root my Evo 3d but it keep saying this
CAN YOU HELP ME PLEASEEEEEEEEEEEEE!!!...????
boone
