Rooting problems!!
tazman1963
150
17
Download THIS: http://www.mediafire.com/?z8kut90ai2qg5t9Seems to me from that link you supplied the answer is right there, download and flash the 2.6 version of clockwork as it supports amend scripting, making sure to rename it to PC36IMG (if its not already named that) place it on the root of the sd card, power off phone, then hold volume down and power button down until it boots into bootloader, press power button once, in a few seconds it will scan for PC36IMG you placed on root of sd card, select volume up to say yes to update, once it finishes select no for reboot and then select recovery with volume button, power to select, you are now in recovery!
Sent from Looney Tunes Central!
