Running Hot and slow charge
noteiii007
109
Anyone finding it runs very warm to hot even after setting and syncing it?
Also find thst it doesn't fast charge with Supplied cable and USB fast charge Plug.
Mine shows that it is fast charging with supplied cord. Shows 46 minutes to a full charge from 65%. It did get hot after the Smart Switch, but cooled down after all the apps were installed.
Dang more! Apart from the gorilla glass 5 Being able to scratch easily, overheating issues too I'm feeling some buyers remorse!
With the fast charge, the less battery the faster the charge. More battery? Slower charge.
Ppl are going to ignore this post. They don't want to believe that the note is already bad
I do believe that A note could be bad. I don't take 1 report and extrapolate it to the entire line. Far, far too many variables to blame the device on 1 reported "issue"
I charged mine completely before turning it on and set up as new. I haven't put it back on the charger to test the speed, but mine hasn't really gotten hot. It did get pretty warm when I was walking my dog, but all my phones do that in the hot GA sun.
Do you just lurk to post negative things on Samsung phones? I realize you're a Nexus fan, but please don't just attack a phone you have no intention of ever owning. Thanks.
Mine has no issues so far. Fast-charges, and was not hot (outside of me downloading 75 apps in 30 minutes :-)
If it's like the Note 5 getting hot when charging is normal and nothing to worry about. Also it will get hotter if it's in a case while charging.
My Note 5 specifically mentions in the settings fast charge will cause the phone to get hot so I'd expect the same with 7.
Don't know if ur coming from the note 5. But remember this does have a bigger battery. So it will take longer.
pcjordanellis
