running out of storage
ybcthanerd
302
I need help asap im constantly deleting apps as up dates come out twitter, facebook, youtube, chrome all up date and i always have to delete apps to free up storage. Screenshot_2013-10-13-02-19-39.png
Analyze this 10GB storage space of apps with a tool like DiskUsage.
Look at apps which need big space for their data.
Look at the settings of such app for the option to move their data to external SD card.
But maybe you've simply to many apps installed ;)
None of the app are able to be moved im on a note 2. I deleted most of my app mostly everything now is tha stock apps that u cant delete.
Sell the note 2 and get a note 3. Verizon is forced to carry the 32gb Note 3 because Samsung wisely cancelled the 16gb.
Sent from my SCH-I605 using AC Forums mobile app
Delete large games. Normal apps won't take up that much space unless you have like a hundred installed. Delete games you don't play. Problem solved.
Also get an SD card and tell your phone and browser to save camera stuff and downloads to the external card. A 16 GB Samsung super class 10 card is $20 or less these days. 8GB class 6 can be had for less than $10, and is probably enough from what I see.
Though I cannot see if you have one installed. I'm assuming not.
Sent from my Galaxy S III using Tapatalk 4
If you use Google Play apps, the music, magazines, books, et cetera they cache can add up quickly, too. You can clear them from inside those apps or your device settings.
I have a 16gb Mc installed but I use Chrome browser and cannot download straight to tha Mc and I don't have any games installed
When you get an "insufficient storage" message, clearing your apps cache will likely solve the issue.
Go into settings->apps and check apps individualy, or search for a good cache cleaner in the playstore.
dobebmo1
