S Note compatibility between Note 3 and Note Pro 12.2
Fruuk
17
I'm a Note 3 owner and am thinking about getting the Note Pro 12.2 primarily because I'm a big S Note user on the Note 3 but am looking for a bigger screen to take all my notes on.
Just wondered if anyone knows the answers to the following:
1. If I create a note using S Note on the smaller screen of the Note 3, will the note scale up nicely on the larger screen of the 12.2, or will it look too big/small (and vice versa)?
2. What cloud solution should I use to sync notes created using S Note so that they are available on both the Note 3 and Note 12.2?
Any info greatly appreciated
I currently use both the note 3 and pro. Scaling has not been an issue and I sync with Evernote.
You can sync with Evernote or Samsung. One thing I've learned is that if you want to lock a note with a password, you need to sync first and lock it on each device.
Ellieeeeee
