S Note for PC - sync help
sandiegosteve
10
I'm working hard to figure out how to use S Note and keep organized.
I just found this: S Note for PC
It seems pretty cool. I am able to see notes (almost), edit them and sync with my device. I am using Evernote to sync.
When I started it up, I saw no notes even after entering EN information.
Then I created a note with the PC app. It shows up in both EN and on my Note. I opened it on the Note, added a picture and it synced to both EN and my PC. Very cool.
But... it puts it in the "Pictures" folder on EN. I can't find any way to configure a folder for sync.
I want to keep my notes organized in EN, and random notes in "Pictures" and "Notes" isn't going to cut it for me. This is so close...
I can stay sync'd with snow fine so I know that works. I have not tried it with EN. Sync with snot once and see if it's an EN problem....
Sent from my SM-P600 using Tapatalk
i can sync the notes i create on my snote pc with evernote and then edit them on mobile snote on my evernote android client.
but the notes i make on snote android syncs up with evernote on windows but not with snote windows client.
in simple words,
snote on pc => evernote server ======> evernote android=> android snote -------working fine through out
but,
snote android => evernote android=======>evernote server====> evernote on pc (till here working fine ) but==XXXX==> (blocked) snote pc
hepl please!
If I create on the pc it won't show up on my note 10.1.
But it works the other way.
If I add any content to any notes it doesn't sync either way.
Is there some settings etc I need to change.
Back to onenote.
Kev...
levabkomo
