S Note help
Hmm good question ... I would like to know this too
Can't say as it's possible. You can back up your notes to Evernote so you don't loose them but they import as jpeg files. Samsung is very helpful with moving data. Call them and see.
BTW the Samsung search function is a beast. In seconds it will search all tour notes, email, contacts, messages and Evernote.
Thank you for the reply guys :)
I believe there should be a way to do this via another app... if I do find a solution I will post it over here.
boone
