S-Pen for Note 2 and Note 8.0
cdf3
1,420
51
I was surprised that my S-Pen for my Galaxy Note II didn't work on my Galaxy Note 8.0.
However, the S-Pen for the Note 8.0 worked on both devices.
Sent from my SCH-I605 using Tapatalk 4
Manky Boy
Active member
Sep 28, 2013
29
Have a note 2 and 8 and mine are definately not interchangeable.
HypoDest
91
Not sure why mine does not
Sent from my GT-N5110 using Tapatalk now Free
Was the note8's spen still in the holder when you tried using the second pen?
There is a battery saving feature under s-pen settings which disables pen detection when a pen is in the holder.
Sent from my GT-N7100
ehosey2
547
I am thinking the OP's S-Pen issues come down to the S-Note pages on the devices are in view mode when trying to use the pen. Tapping the icon on the bottom left corner should switch between edit mode and view mode. The S-Pen of both devices should are interchangeable on my Note 2 and Note 8. Also when testing this each pen worked while the device being tested had its respective pen in its holding slot and battery saver was unchecked in both Notes.
Sent from my GT-N5110 using Tapatalk 4
cdf3
1,420
51
Thanks! Your advice worked.
AIDAVEY
