S Voice Problem with Galaxy Note 3
Batman8888
131
Anyone else having a problem with S-Voice constantly turning on "voice control"? I continue to turn "voice control" OFF in settings because the phone will otherwise randomly turn on and either play music, or launch S-Voice where it's then waiting for a voice command. This can be dangerous because I don't want it to over hear the television in the room or someone talking then mistake that sound and try to voice dial someone without my knowing...then of course that person could answer and just listen in on your household conversations!
I can tell that it keeps turning on (even when the settings says it's off) by looking up in the notification bar and seeing the little microphone icon. When it is showing, I proved that it has turned on voice control by just saying "hey Galaxy" and the phone responds to me when it should NOT!!! Also, when that mic icon is showing I can't use other apps that require that mic like Google Search (it will say that Google can't be found at the moment). This has caused me to disable S-Voice altogether which I didn't really want to do since it is the only way to really use voice dialing with the Galaxy Gear. I have also already tried clearing the cache and data for S-Voice which didn't help.
Any ideas?
S-Voice has been an on-going problem for me even BEFORE rooting. I have never had much luck with the app on my GS3, Note 2, Note 3 or on my Galaxy Gear!
I've not had any problems with S Voice on my note 3, but more recently (this last gear update) I've had problems with S Voice not starting to capture automatically when opened, either via double press of power key or by tapping S Voice reply.
I posted a similar problem with s voice.
Somehow I have launched s voice on my s4 and now even when I turn it off or try to disable it just keeps coming up. Mostly @ un opportune times. How can I turn s voice off completely it's so annoying. I'll be in the middle of something & if it connects to wifi or a text comes in etc.... The stupid thing launches and says "ask Galaxy"
Gary59t
