s10+ loads everything faster than my note 10+
Matthew Stegman
246
My wife has an s10+ and I have note 10+. When we play call of duty mobile her s10+ ALWAYS loads at least 5-10 seconds faster. Its not just call of duty that loads faster, its everything she does.
I've noticed mobile data only so far. both are on AT&T unlimited data. I've noticed this with the note 10+ I had before I got this replacement device as well.
Hmm...you can try in settings>general management>reset >reset network
See if that helps
AT&T can't (won't) explain why my note 10+ is slower than my wifes s10+. And they won't replace it for that reason.
Do you have a case on your phone? Some poorly designed cases can interfere with the data signal (e.g., if there's metal in the case).
at first I noticed an improvement but then seemed like it got worse again.
-WCDMA preferred
-GSM only
-WCDMA only
-GSM auto (PRL)
-CDMA auto (PRL)
-CDMA only
-EvDo only
-Global auto (PRL)
-LTE/CDMA auto (PRL)
-LTE/UMTS auto (PRL)
-LTE/CDMA/UMTS auto (PRL)
-LTE only
-LTE/WCDMA
-TD-SCDMA only
-TD-SCDMA/WCDMA
-LTE/TD-SCDMA
-TD-SCDMA/GSM
-TD-SCDMA/UMTS
-LTE/TD-SCDMA/WCDMA
-LTE/TD-SCDMA/UMTS
-TD-SCDMA/CDMA/UMTS
-Global/TD-SCDMA
-Unknown
NameRingtone
