S10+ OEM charger making buzzing sound?
AlphaBeepBeep
241
6
18
Hi, the chargers included with both of the note 10+ I've bought making a buzzing sound when plugged in. Anyone else?
it's fairly loud. both cables and bricks. tried different outlets. same results. my s10+ didn't have this charging brick issue.
get a warranty replacement straight away, if nothing else than for piece of mind, I look at charging like I look at vehicle brakes, it needs to be safe 100%
Sounds scary.. I don't have that issue, yet my phone gets slightly warm while charging. Nothing too concerning, I just figure with faster charging, a warmer device wasn't too unreasonable.
I'm also using a surge protector, haven't plugged straight into an outlet.
Definitely going to follow this
I only bring it up because I dated someone that bought a charger off Amazon and it made a buzzing sound. woke up one day and there was a burn mark under it on our white dresser. threw it in the trash.
I'm sure I just got unlucky with two bad chargers. I was wondering if anyone else experienced this.
I never use wired chargers but checked the two I got just to see if they make a sound, and didn't hear anything.
Not necessarily the best example lol! The buzzing isn't dangerous in anyway. It just means your charger is ready to give out on you. But i guess if a charger were brakes, then yes id treat them like such. But if the charger dies, you just buy a new one. Your brake give out, then you die.
