S21 Ultra not going into Deep Sleep
macgd016
I have a S21 Ultra & S21 Plus. Using Battery Guru i can see that the plus spends loads if time in Deep Sleep when not in use but the Ultra almost never does. I've done a factory reset and tested in Safe Mode but the result is the same.
Its begining to look as if this is just the way the Ultra works so I wonder is there anyone out there with a S21,Ultra that uses Battery Guru or other app than can see if there phone ever goes into deep sleep when not in use
you could turn it off if not using!!:cool:
this might be of interest to you!!
That would certainly save battery but isn't very practical.
The issue is battery use, because the phone never seems to go into a Deep Sleep it eats battery. 16% or so in 8 hours overnight with no use
abhifineproducts
