S22 Ultra - My battery life has taken a DUMP
felloffthetruck
Trusted Member
Mar 31, 2013
8,616
24
38
Since getting all the latest updates my S22 Ultra's battery life has taken a dump.
Am I the only experiencing bad battery life lately?
Same here ... Charging a couple of times a day. I thought it was Nova too but still having bad battery life without it.
Think I'm going to bite the bullet and factory reset and set up fresh ...
Sent from my Samsung Galaxy S22 Ultra 5 Gangsta Alpha Omega Supreme
Nothing has changed for me since the final 13 update also running One UI for about 2 weeks stopped using nova.
Sent from my SM-S908U using Tapatalk
Interesting for me it's been very bad...also when I plug my phone in and use android auto it's like three times worse...isthere a way i can do a backup so I don't have to set phone all the way up when I factory reset?
You could try > Clear Cache Files from the phone's System Partition Section > https://forums.androidcentral.com/e...lear-the-cache-on-my-device%2F&token=X9H9iDd2 You may need to insert your earphones or hook upto a powered On Laptop to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too.
My S22+ is a little worse after the update, but the app usage remains the same? I'm hoping it settles down after a couple more days.
Mine started out bad but seems to have settled down back to what it had been previously.
Sent from my SM-S908U1 using Tapatalk
lordnico86
