S23 ultra need help!
RAvEcREAToR23
182
18
1 thing maybe is option to do AOD to be always bright? Like was on note 20 ultra can choose it be bright or not or adaptive. On one ui 6.1 it is only adaptive 😵 not found how change . maybe is app that allows that.
2 thing on s23 ultra when get notifications screen turns on for second and then AOD again. So not found how disable it for turning on. Or again maybe is some app that allows screen stay off . Really not need screen turns on it's just ANNOYING 🤢🤮
As to the brightness issue, on the One UI 6.1, S23, you can still choose whether to have a certain brightness level, or make it adaptive. Or choose extra brightness. Go to Settings /Display/Brightness
Try Fine lock in play store I think it's an alternative if Good Lock is not in your region
Marlene
