S3 Mini Charging Problem.
Ali_K_12
4
Hi, my s3 mini was charging this morning to about 30/40% I then took it off charge to use it as I was out. The battery then went dead, I got home about an hour later and it won't charge. I have tested the charge on my SG tab and it charges fine. Any suggestions??
Welcome to the forums! Sorry you didn't get an earlier response.
Did you read through the various charging threads to see if they had anything to offer?
Typically you'll want to take the battery out for a few minutes, then reinsert it (but don't attempt to turn it on) and connect the charger. You should see a static battery graphic followed by another graphic showing the battery level and charging activity. Leave it overnight if you have to.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
Yes I did remove it left it overnight e.t,c and it won't charge, there's no lint/dust in the USB port either, thanks.
Hmm...how old is the battery?
I don't suppose you know anyone else with a Mini?
No unfortunately I don't :'( I bought the phone as i liked android but the S3 was too big for my taste, had I had an S3 now I could have simply borrowed a friends battery ='D
Ap2300
