S4 is running out of storage space...will microSDXC UHS-I card [64 GB] solve the problem?
  • Start date Start date
I have a 16GB micro sd card in my phone & my phone memory is still running out. All my music, videos & pictures are on the sd card. Can't delete any apps as I use all the ones I have. All I do now is clear the cashe about once a month.
The sd card is not an extension of the internal memory. Apps and their included data is stored in the phone memory. You can move music, photos, videos and some apps that have a lot of data allow you to store the data on the sd card. It takes a lot of apps to fill up the internal memory unless they are some games that has lots of data it needs access to on the fly. You have to decide which ones are important. It is easy to reinstall an app if you need it occasionally and then delete it after you are through!
A search for SD Card or memory in this forum will find a lot of fixes and solutions other have found!
You can move some apps to the SD card via application manager. Not all apps are allowed to move, however.
r3dpuk3
