S5 battery cover "crack" noise
vil dric
Hi !
First sorry for my english.
I bought a new S5 neo and I noticed something strange. When I press softly on the battery cover on the left side, it make weird cracking noise and open a little bit on the bottom left side (very minimal but its not perfectly closed). I chose the S5 because its waterproof (i am a fisherman) and the fact that the cover open even if its very minimal dont make me safe on the water.
I tried to remove and reinstall it a few times, and nothink look broken or whatever.
Is this "normal" or I am he only one to experience this problem? Do you think water will penetrate?
Thanks!
Here is what a genuine OEM cover should look like on the inside...
