S5, volume (lock, select.) too loud... since Lollipop 5.0
Philtronic
Active member
Sep 27, 2014
39
Hi !
This is something that bother me since the update to Lollipop:
The minimum volume of the system sounds (lock, unlock, selection, etc.) is too loud.
I mean, I set it to the minimum but it's still louder than before Lollipop. Am I the only one in this
situation ? I really don't want to clear my phone... Other sounds (notification, ring, etc.) work as supposed, no problem there.
Thanks for your help !
P.
Mine seems to be the same as KitKat.. Are you using this settings menu?
Posted via the Samsung Galaxy S5
Yes, same menu...
The problem is with the "System" sounds... the minimum volume is the same as the KitKat max volume...
Looks like a complete reset is in order.
Thanks
For those interested, don't loose your time, it did not change after a factory reset or even a complete wipe and download of Lollipop with Kies.
Hi !
P.
That's funny, I just posted a questions about this. I've noticed that the keyboard clicks and swipe to unlock sound are insanely loud. Turning down any of the sound options don't do a single thing. It seems as if the lowest setting is barely a difference. I guess I may have to keep my keyboard and swipe sound muted. Which super sucks cause if I wasn't for that 5.0 would be perfect in my book!
Oh boy, exactly !! I also muted my keyboard and swipe sounds... At least we have keyboard vibration, it's probably better than nothing.
And I don't want to downgrade to KitKat because I gain a day and a half of battery time with Lollipop... On the positive side, after the
complete wipe / clean install, my phone just fly !!
Go to "setting" - "device" - "sound and notifications". You can see ringtone, media, system sound volume and notification. Most likely lock and keyboard sounds related with "system sound".
itsnotmac
