S6 edge and Xmod
Status
Not open for further replies.
Ronnie Tyler
Hello everyone this is my first post I'll get right to the question
I have an S6 edge I want to use xmod on it I tried the method where you root the phone first then use lucky patcher to convert the xmod app to system app I did the method on note 3 version 5.1.1 and note 4 5.1.1 for my friend and the xmod worked but when I tried to do the same method I didnt work the problem I'm facing is whenever I try to convert the app to system and after the reboot the app doesn't i appear i tried rebooting it several times then i downgraded the phone to 5.1.1 and tried the method it didn't work then i download a firmware from sammobile i thought maybe on another firmware it will work but it didnt i tried another firmware and it didnt work then i tried the method of root explorer copied the app to system/app and that method didn't work either so if you anyone of you could help me I'd be really
Sorry, we don't allow discussion about Lucky Patcher. Thread closed.
Status
johanchsirisa
