S6 Edge - Please help with PDFs
haidardoc
Hi there. Just got the edge. Switched from iphone 6. Everything seems to work fine.
I have many pdf files i use very often. I would like those files only to show in the document folder when viewing this folder from my files.
When i open documents folder from my files every single document file on the phone is shown. Is it possible to hide those files and show only the pdf files i frequently use?
Welcome to the forums. The only way I can think of is to create a folder just for PDF files. I do not have the device, but I am calling in for some help from those that do.
I don't believe so, but you can open the pdf with Adobe Reader, then adobe will keep a record of recently opened pdf
Sent from my Pearly White Verizon Samsung Galaxy S6 Edge
kali-arm64
