S6 Edge + Sound Quality
jexx
335
I've never had a Samsung device before and would like to know from those of you that have one? I sometimes work in a noisy environment and have to use the phone function.
Making and receiving phone calls, quality? Speaker phone function and quality of sound using earbuds. THX
Bump! I'm debating between this and waiting for the LG V10, and audio quality is very important, specifically over headphones. So any info would be rad.
LAGalaxFan77-
Looks like we will never know, guess it's is not that important?
I've read on XDA that the sound quality (via headphones) for both the Edge+ and Note 5 is the best ever. Not my words but I will say, as a former musician, I do agree. Great sound quality.
Great sound quality and loud as well
Sent from my SM-G928V using Tapatalk
I came from an HTC One M8 and in comparison to speaker volume, they are similar. It has pretty outstanding external sound considering the speaker is at the bottom. There is actually an option for extra speaker volume via a button when on a phone call using the external speaker. As far as the sound with headphones, it's as clear and loud as I've ever experienced. I use the htc one headset because it's my favorite and I also use high end headphones at times.
I have an S6 and an Edge plus at the moment and I can tell you the S6 sounds the better of the two. Volume is approx the same but the S6 has more depth and bottom end. The Edge plus sounds a little "tinny" in comparison. It's not bad by any means but the S6 is def better here.
